Re: wanting to know
Posted by Robin Broders on September 22, 2002 at 08:45:00 from (207.32.45.194):
In Reply to: wanting to know posted by Now wondering M rod on September 21, 2002 at 14:31:01:
My I&T shop manual lists the following information for M crankpins. M prior to 278050 2.4975-2.4985 others 2.5475-2.5485. Running clearences M prior to 278050 0.002-0.003 others 0.0011-0.0037. Side play M prior to 278050 0.008-0.012 others 0.005-0.012. Replacement bearings appear to be avalable in Std, 0.002, 0.010, and 0.020 oversize. Rod bearings are renewable from below, just drop the oil pan, flatten the washers that lock the bearing cap bolts and unscrew bolts. Bearing should slip right out. Just did this to my SMTA, took about 4 hours. Used a pair of vice-grips to bend new lock washers, one jaw on bolt head the other on washer, took about 4 bites to get washer locked right.
Post A Followup
: Re: Re: wanting to know
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
