Farmall Tractors Discussion Board
Re: Re: Jump start an H
Posted by Farmall Gray on August 20, 1999 at 08:27:19 from (205.188.193.152):
In Reply to: Re: Jump start an H posted by Pappy on August 18, 1999 at 14:41:04:
You will cook your jumper cables alot more quickly with a 6 volt than a 12 volt. With a six volt,the amperage requirement is so high that you would need jumper
cables the size of garden hose. I have jumped 6 volt tractors many times with 12 volt batteries.
The only time I had any problem was when my helper hooked it up backwards. You have to hook them up + to + and - to - on both batteries. If you dont want to make the last connection at the battery, hook the - terminal on the 12V to the - terminal on the tractor's battery and the + on the 12v to a good ground on the tractor.
Post a Followup
: Re: Re: Re: Jump start an H
Today's Featured Article - The Mud Daubers and the Old John Deere - by Jon Zehnder. I have a 1941, John Deere Model A tractor I have owned for about a year and a half. This is my first (in case my wife reads this, "FIRST") tractor and it has been a learning experience. After considerable advise and assistance from local tractor nuts and the forums of Yesterday�s Tractors, I had finally got it running pretty well. I have tuned it up, overhauled the carburetor, installed a borrowed, rebuilt magneto, installed a new Power-Trol, patched the radiator, installed new front wheels a ... [Read Article]
