Re: M w/ Puff of blue smoke
Posted by Dan on July 14, 2002 at 08:57:04 from (12.18.158.25):
In Reply to: M w/ Puff of blue smoke posted by Jack on July 14, 2002 at 05:21:35:
I would put some more hours on it before I started worrying too much. Puff of smoke at starting usually indicates valeve stems not sealing so a small amount of oil runs down the stem when the engine is shut off. With the compression you have the rigns must be good. You may have one valve guide that is a little large but even if this problem keeps up after breakin it really isn't that bad. At least you know the valves are getting lube
Post A Followup
: Re: Re: M w/ Puff of blue smoke
Today's Featured Article - 50 Tips for Ford N Owners - by Bruce Haynes. Over the years of owning these three tractors, I have managed to refresh what little mechanical knowledge I had and add a little more, thanks to the wisdom and helpfulness of many fellow N owners. So, now it's my turn to share a few of the tips I've picked up. ... [Read Article]
Latest Ad: Massey Ferguson model 65 diesel tractor [More Ads]
