Re: 300 Utility Hydraulics - Loader hook up?
Posted by dick on May 12, 2002 at 10:26:57 from (63.211.242.112):
In Reply to: 300 Utility Hydraulics - Loader hook up? posted by Carsen on May 11, 2002 at 21:40:52:
In theory, at least, you can get rid of all the extraneous hydraulic stuff, and just use what was originally available from IH to do the job. Practically, it may not be worth doing, and/or you may not like the results. The standard hydraulic pump for the 300U (mounted at the distributor) had a capacity of 10GPM (when NEW) and the system was rated for 1200psi, which is pretty low by today's standards. If you are lucky enough to have power steering, subtract some allowance for that, and then figure out how long it will probably take to raise your loader based on the diameter of its cylinders, 231 cubic inches/gallon, and the probable capacity of your pump at this point in its lifetime. IH also offered a front-mounted 16GPM pump for applications requiring more capacity than the standard pump supplied, and using this type of pump may make the most sense if you decide to pursue this. The standard Hydra-Touch system allowed use of up to three valves, two of which you would need for your loader, with the third remaining for your hitch. All you have to do in this case is hook up hoses the respective cylinders (assuming they're all double-acting), make sure the control valves are set for double-acting, and it should do something, however slowly and/or weakly. If the extra valve assembly you refer to isn't part of the original IH Hydra-Touch system, things get more complicated. The IH system was a three-port design (supply, return, and control lines are involved) and melding an exterior loop into the original system isn't straightforward. This resulted in the wide variety of strange-looking add-on systems you can see on these tractors, but they were probably the most practical choice at the time they were added, however unlikely that appears today. Sorry for the long post, but there are a number of issues to consider. Shoot me an email if you want further input.
Home
| Forums
| Order Support
Today's Featured Article -
Talk of the Town: What's The "Stuckest" You've Ever Been? - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I was about 14 (part of the problem) when I got stuck. I was disking with a cab equipped IH 966. The window was dirty and I was driving into the evening sun. It was hard to see and it was my first pass down the field. I got the tractor so stuck that the underside of the tractor was resting on the ground. My uncle wanted
... [Read Article]
Latest Ad:
65 Massey FERGUSON DIESEL
[More Ads]
Copyright © 1997-2026 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
