Re: International I-4 (W-4) light switch question
Posted by Farmer Bob on March 12, 2002 at 18:22:59 from (66.152.73.159):
In Reply to: International I-4 (W-4) light switch question posted by Prune Picker on March 12, 2002 at 17:24:32:
On the three position "Light" switch you have the furthest CCW position is "Off" meaning you literally have shut off the lights that aren't there. The next setting or click is for front dim lights/bright tail light and the furthest CW setting is for bright lights. Charging is controlled by the voltage regulator.
If you had the older 4 position switch you would then have a cut-out relay vice a regulator and the furthest CCW setting would be for low charge, then High Charge, dim front lights, bright lights. Hope this helps.//FB
Post A Followup
: Re: Re: International I-4 (W-4) light switch question
Today's Featured Article - Major Problems - by Anthony West. Following the aquisition of the two Fordsons to my collection I found that I was struggling to move them about. I had considered the possibility of driving the "F" to and from shows but anything other than local rallies was totaly impractical due to its sedate pace. I had also considered buying a landrover and trailer, but the price of a ... [Read Article]
