Re: Re: Re: 10-20 FAN BELT
Posted by Bob Kerr on March 08, 2002 at 07:50:31 from (152.163.213.207):
In Reply to: Re: Re: 10-20 FAN BELT posted by [email protected] on March 08, 2002 at 01:01:52:
you won't want to use "Alligator" lacing. it is for very heavy applications. Clipper lacing is the wire type that most people use like that, but if I was going to use leather, I would have it "skived and glued". Skiving is cutting the end of the belt kind of like a long bevel. the other end of the belt is beveled the opposite way and then they are glued together. that way there is no metal lacing parts to cause the belt to fail becuase these pullys are too small of a diameter and it "works the lacing" too much.If you see a failed belt it is almost always broken where the lacing pokes through the holes in the belt. I learned all of this from a friend who worked in an industrial belting and power transmission shop. we traded some parts I had that fit his car and he(we, I helped) made heavy duty belts for my gristmill. Also , Will, don't run very much tension on that belt! The needle bearings in the fan hub can't take much load like that and be sure to lube them with 140wieght gear oil. Gun grease won't let them turn right and when the needles flat spot, they chew up the race quicly. You just want enough tension where the belt won't slip on the fan hub when it is running, when the engine is off it should slip easily.It will flop some but that is normal and it will settle down with some time as the belt shapes itself to the pully faces. If you look at a bunch of junk tractors that have flat fan belts, you will notice they all have replacement fan hubs, and that is because of over tensioning.
Home
| Forums
| Order Support
Today's Featured Article -
My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha
... [Read Article]
Latest Ad:
1965 International Harvester McCormick Farmall cub tractor 2,500. Two owner tractor. My grandfather bought new in 1966, then we inherited it. Have all the paperwork original manual and all maintenance records. It starts and moves. Comes with underbelly mower, plough, and some other attachments.
[More Ads]
Copyright © 1997-2026 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
