Re: 300U Transmission Oil
Posted by RPM on February 22, 2002 at 06:55:29 from (63.110.182.225):
In Reply to: 300U Transmission Oil posted by Jim on February 20, 2002 at 21:33:30:
If you plan on keeping and using the tractor for your peace of mind change all of the fluids, it should be done yearly anyhow. As far as what you put back in, I would say 50/50 mix of Hytran & gear lube in rear frame/transmission, it takes 7 gal, mix if you are cooler climate, drawback of straight Hytran is leaks easier, put only Hytran in hydraulic system, 13.5 quarts, It is made to discolor to milky white when to much water is present. As far as what you put in tractor its more of a problem of the lack of lubricant than the exact type. The mix is ok, we have done this a long time on combine final drives, used 80/90-85/140 + Hytran.
Post A Followup
: Re: Re: 300U Transmission Oil
