Farmall Tractors Discussion Board
Re: Super A and Brush Hog
Posted by J Risher on July 18, 1999 at 19:55:54 from (63.67.89.216):
In Reply to: Super A and Brush Hog posted by BW on July 18, 1999 at 17:51:21:
I use a 4 foot bushhog on my SA. It is a drag type
that hooks up to the drawbar. I offset it all the way to the left,so the shaft will line up better with the gearbox on the bushhog. I have hooked chains to mine and lifted the back wheels to clear the ground, but it really strains it. As for power,my SA can handle the 4 ft. but if the grass or weeds are tall it pulls it down pretty fast. I usually take only half a cut when it does this. I would think that if you hook it up without correcting the offset, you would likely sling out the pto joints.
Post a Followup
: Re: Re: Super A and Brush Hog
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit ... [Read Article]
Latest Ad: WANTED IH C200 gas engine — complete running motor Wanted complete used IH C200 gas engine in running condition for an International 574 gas tractor. My block has a hole in it and is dead, so a rebuild kit wont do it — need a whole running motor. The C200 also came in the 544 and 674 gas trac [More Ads]
