Farmall Tractors Discussion Board
Re: Super A clutch
Posted by Kent Morris on June 11, 1999 at 07:21:07 from (205.188.192.22):
In Reply to: Super A clutch posted by michael 'the legend' on June 10, 1999 at 20:44:57:
Micheal,
The best fix is to split the tractor and do the job right. Even if you do manage to free the clutch without tearing it down you will have a problem. The transmission input shaft has very little drag on it and any friction at the clutch will make it difficult to shift. I have a Super A that had a stuck clutch and I was able to free it. However there is enough friction for the transmission shaft to turn and I have to throttle down to idle before shifting from neutural to prevent grinding the gears.
I have other tractors with the same problem. Some of this can be cause by the Pilot Bearing. So, when you split your tractor to repair the clutch make sure you service the pilot bearing as well.
Good Luck,
Kent
Post a Followup
: Re: Re: Super A clutch
Today's Featured Article - Torque Wrenches - by Curtis Von Fange. When working with fasteners a torque wrench can play an important role in the correct assembly of critical equipment components. Lets examine in detail some of the reasons for using a torque wrench along with how to correctly use the variety of wrenches available. Applying the proper torque to a fastener accomplishes a number of tasks. First of all correct torque will hold the parts together. This may seem like a trite statement but � think about it for a second. Engineers have designed ... [Read Article]
Latest Ad: WANTED IH C200 gas engine — complete running motor Wanted complete used IH C200 gas engine in running condition for an International 574 gas tractor. My block has a hole in it and is dead, so a rebuild kit wont do it — need a whole running motor. The C200 also came in the 544 and 674 gas trac [More Ads]
