350 utility rocker arms won't move
Posted by Jeff in Cincy on March 09, 2009 at 05:30:50 from (63.250.143.9):
This is not good. It died on me and I towed it back to the barn. At first I thought it was a carburation problem as it was not pulling gas up the intake Then I pulled a plug and realized I have no compression. Popped the valve cover and I see no movement on the rocker arms at all. However the distributor is still firing. Now I am leaving it sit for a warmer day.
Any ideas? I am hoping maybe a timing gear broke. Or maybe the cam broke. I am not sure what drives the distributor. I guess i will find out when I pull the front off the engine. I thought I would post this to see if anyone had this happen to them.
Today's Featured Article - Box Plow Blues - by Tom Schwarz. One of the first implements most tractor owners obtain is the box plow. For very little money, this piece of equipment promises to plow and flatten any hill or vale on your ranch road or farm. At least that's what I thought! As simple as a box plow appears, it can be rather challenging to make work correctly. In our sandy soils of Florida, traction is king. You can never have wide enough tires or heavy enough weights to get all the traction you want � unless you own a monster tractor. U ... [Read Article]
Latest Ad: Wanted to buy model 65 massey ferguson 65 diesel [More Ads]
