Farmall Tractors Discussion Board
Re: Re: Re: Re: Farmall Cub carburator
Posted by walter on May 14, 1999 at 05:41:15:
In Reply to: Re: Re: Re: Farmall Cub carburator posted by Jim Becker on May 13, 1999 at 20:12:15:
Had the same problem with my '64 lo-boy. I took a flat piece of iron and a brass drift a began tapping on the warped top until I felt I had it straight enough to use, I also took the bowl part of the carb turned upside down on flat iron with emery cloth and sanded it until it was smooth. The whole process took me about 3 hours before I was happy with the fit, I then put a complete rebuild kit in for $48. It now works just fine and does not leak a drop.
Post a Followup
: Re: Re: Re: Re: Re: Farmall Cub carburator
