Oil Pressure Port on 806?
Posted by chadd on June 17, 2007 at 21:52:27 from (4.188.132.38):
I have a question on a D/DT-361 or D/DT-407 engine block. I want to check the oil pressure on the motor with a gauge, however, I don't want to touch the sending unit, as I doubt it will come out in one piece. I noticed that on the left side of the block (when sitting on the tractor) right in front of where the block ends and the clutch housing starts, there is a small plug. The lines for the power steering run in the vertical direction right on top of it. It is exactly in line with the sending unit port, so I was wondering if this could be used to attach the gauge or not.
Thanks.
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha ... [Read Article]
