Re: Changing tires and rims
Posted by Bob M on May 28, 2007 at 09:05:19 from (69.205.124.61):
In Reply to: Re: Changing tires and rims posted by MI Bill G on May 28, 2007 at 07:02:27:
USUALLY the clamps will pop right off after loosing the bolts.
However if the clamps don't loosen, a few licks with a sledge on the inside rim after removing the bolts will loosen 'em up. Or you can loosen the clamp bolts 2 - 3 turns, then SLOWLY move the tractor forward and backward at least 1 full revolution of the rear wheels.
Also like Hugh suggests below, a 3/4" socket and about a 4' pipe "cheater" should loosen the bolts/studs without difficulty.
Today's Featured Article - The Mud Daubers and the Old John Deere - by Jon Zehnder. I have a 1941, John Deere Model A tractor I have owned for about a year and a half. This is my first (in case my wife reads this, "FIRST") tractor and it has been a learning experience. After considerable advise and assistance from local tractor nuts and the forums of Yesterday�s Tractors, I had finally got it running pretty well. I have tuned it up, overhauled the carburetor, installed a borrowed, rebuilt magneto, installed a new Power-Trol, patched the radiator, installed new front wheels a ... [Read Article]
