Re: Custom exhaust with down deflector
Posted by Hugh MacKay on May 27, 2007 at 17:47:43 from (209.226.106.87):
In Reply to: Re: Custom exhaust with down deflector posted by SDP on May 24, 2007 at 06:32:48:
SDP: Basically what ended the horizontal exhaust on tractors was up keep and the fires they started on the ground. Fires were particularly bad in hay making operations. Heat was another factor, MF had that pipe under the left floor board and it almost fried ones left foot. On utility type tractor with fenders it created a hot operators platform, and suprisingly it didn't get rid of fumes.
The C is a rather unique situation as the operator is higher in relation to the hood than all other Farmalls, thus it takes a long pipe to put the fumes above you. Your going to swear at the upright exhaust on a C if you start mowing around ornamental trees. If you do put an exhaust out under a C axle, at least you wont be as close to it as on utilities.
Today's Featured Article - The Mud Daubers and the Old John Deere - by Jon Zehnder. I have a 1941, John Deere Model A tractor I have owned for about a year and a half. This is my first (in case my wife reads this, "FIRST") tractor and it has been a learning experience. After considerable advise and assistance from local tractor nuts and the forums of Yesterday�s Tractors, I had finally got it running pretty well. I have tuned it up, overhauled the carburetor, installed a borrowed, rebuilt magneto, installed a new Power-Trol, patched the radiator, installed new front wheels a ... [Read Article]
