Re: 6 to 12 volt conversion
Posted by John T on May 16, 2007 at 12:41:41 from (66.244.83.147):
In Reply to: 6 to 12 volt conversion posted by Mark / Wi on May 16, 2007 at 12:26:24:
Yes, The starter will still function and turn the same direction (i.e. no damage) regardless of polarity. As far as cranking, a 6 volt starter can still work at 12 volts and will spin a lot faster without harm unless one were to let it crank for an extended period which might possibly overheat it. HOWEVER the extra kick in torque can be a tad tough on starter drives (Bendix) and or flywheel teeth but Ive used them and not experienced problems running 6 volt starters at 12 volts. Our friend Bob M just recently suggested the use of smaller battery cables might help reduce potential starter damage when using 12 volts on 6 volt starters.
Of course, there are other ignition concerns and ammeter and coil wiring issues dependign on if youre switching voltages or polarities or both and we can help with as needed.
John T
