Re: Hydraulic Whine on 706
Posted by Allan In NE on May 08, 2007 at 03:42:48 from (148.78.243.24):
In Reply to: Hydraulic Whine on 706 posted by IA Farmer on May 07, 2007 at 20:45:21:
You and that mechanic both know that is BS and for darned sure it is not going to, �Wear in, before it wears out�. He probably figures it is easier to pull the wool over your eyes than it is to spilt that tractor again. :>)
It shouldn't "sing" and that noise is literally screamin' at you that something is wrong.
From the tractor seat, does the noise sound �forward� or does it sound like it is back under the seat? Can you change the sound by moving the steering or does the frequency change when you move the hitch/remotes? If you can change the pitch of the sound, it should lead you to which pump is putting up the noise.
Possible causes are: Plugged filter, wrong gear or wrong gasket on a pump, a split o-ring or leaky gasket in any one of the hydraulic circuits. Since the tractor was just split for repair, you can just about figure where the trouble lies. :>)
Allan
