Re: farmall hood fit problem
Posted by Wardner on May 05, 2007 at 20:53:10 from (4.154.244.6):
In Reply to: farmall hood fit problem posted by bobby macdonald on May 05, 2007 at 20:02:51:
Sounds like something got shrunk or stretched. I'd wager that the hood is larger than it used to be due to sandblasting. You might want to measure a similar hood with a fiberglass or cloth tape measure.
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
