Re: farmall hood fit problem
Posted by georgeky on May 05, 2007 at 20:17:48 from (205.188.116.138):
In Reply to: farmall hood fit problem posted by bobby macdonald on May 05, 2007 at 20:02:51:
Bobby, sounds to me like your radiator support rod need to be adjusted. It is the one right above the valve cover. On one end it is threaded and can be moved in or out. If hood is to tight let it out a little and it will lean the radiator and grill towards the front and get you enough room to put hood where it belongs. It is just below the steering shaft.
Today's Featured Article - History of the Nuffield Tractor - by Anthony West. The Nuffield tractor story started in early 1945. The British government still reeling from the effects of the war on the economy, approached the Nuffield organization to see if they would design and build an "ALL NEW" British built wheeled tractor, suitable for both British and world farming. ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
