Re: I.T.Cub:reverse polarity?
Posted by Dick in NY on April 28, 2007 at 16:11:21 from (152.163.100.197):
In Reply to: I.T.Cub:reverse polarity? posted by Darlin on April 28, 2007 at 15:00:23:
The older Farmall's and cub's used positive ground on their ignition systems
Today's Featured Article - Engine Basics: Spark Plug Cleaning - by Staff. Cleaning procedures: Brush or blow dirt from around the spark plug base. Remove the plug with a correctly fitted wrench. Examine the porcelain insulator and points. If the insulator appears to be melted or blistered, cracked or broken, and the points seem unduly burned it is evident that the plug is operating too hot and it should be replaced with a colder plug. If the plug is fouled excessively with carbon it apparently is operating too cold and it should be replac ... [Read Article]
