Re: Alternator not charging
Posted by Bob M on March 20, 2009 at 08:32:04 from (151.190.254.108):
In Reply to: Re: Alternator not charging posted by chad504 on March 20, 2009 at 07:32:50:
OK - gotta be either the belt adjustment has caused the alternator is now spin too slowly or something's gone wrong with the alternator itself. (I'm guessing probably the latter...)
However if this just is a temporary setup, you can get by without a working generator/alternator. Simply use an external charger on the battery as needed.
With battery/distributor ignition, a good battery, not using the lights and operating the starter infrequently (ie. long continuous runs) you can easily get 15 - 20+ hours of engine run time from of a single battery charge. (I've done it many times...)
And if your tractor has a magneto it'll run even longer...
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
Latest Ad: Looking for a minneapolis moline zts [More Ads]
