Re: h starter springs
Posted by Andy Motteberg on March 17, 2007 at 22:05:34 from (4.143.104.158):
In Reply to: h starter springs posted by baler46 on March 16, 2007 at 20:49:57:
Here is a good cheap kit someone sells online. (not mine). This kit has everything you need for $9.95. Click the link below. Andy.
Today's Featured Article - Engine Basics: Spark Plug Cleaning - by Staff. Cleaning procedures: Brush or blow dirt from around the spark plug base. Remove the plug with a correctly fitted wrench. Examine the porcelain insulator and points. If the insulator appears to be melted or blistered, cracked or broken, and the points seem unduly burned it is evident that the plug is operating too hot and it should be replaced with a colder plug. If the plug is fouled excessively with carbon it apparently is operating too cold and it should be replac ... [Read Article]
