Farmall Tractors Discussion Board
Re: CUB hard to start
Posted by RK Smith on April 18, 1999 at 05:13:09:
In Reply to: CUB hard to start posted by mt on April 17, 1999 at 11:04:31:
if I were you, I would not attempt conversion to a 12V system. You have a problem that you may still have after the conversion. Solve the problem first, then decide if you want to convert. I suppose in one sense, it's kinda like sex.
Post a Followup
: Re: Re: CUB hard to start
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha ... [Read Article]
