Farmall Tractors Discussion Board
Re: Super A Powerloss
Posted by Keith on April 13, 1999 at 15:36:35:
In Reply to: Super A Powerloss posted by JAY on April 12, 1999 at 12:45:40:
when mine did this the inlet in the gas tank was clogged, take the sediment bowl off and remove the valve assembly from the tank GOOD LUCK
Post a Followup
: Re: Re: Super A Powerloss
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit ... [Read Article]
Latest Ad: WANTED IH C200 gas engine — complete running motor Wanted complete used IH C200 gas engine in running condition for an International 574 gas tractor. My block has a hole in it and is dead, so a rebuild kit wont do it — need a whole running motor. The C200 also came in the 544 and 674 gas trac [More Ads]
