Farmall Tractors Discussion Board
Re: Re: F-20 and REG Road Boxes
Posted by Scott N on April 08, 1999 at 09:32:47:
In Reply to: Re: F-20 and REG Road Boxes posted by JW on April 07, 1999 at 20:24:14:
John, I have a '36' F-20 with a Heisler 2:1 overdrive. This is an independent gear box, holds its own fluid, and overdrives all gears and the PTO and belt pulley. With 13-28 rear tires will go 15 mph. Good luck.
Post a Followup
: Re: Re: Re: F-20 and REG Road Boxes
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha ... [Read Article]
