Re: International 574 front crank seal
Posted by Diesel Bob on January 22, 2002 at 15:13:44 from (62.7.56.145):
In Reply to: International 574 front crank seal posted by RGD on January 22, 2002 at 13:26:52:
I have replaced many front crank seals on the neuss built engines and the work is simple.remove crank pulley gaurd from front of the sump slip off the fan belt and remove the 3 bolts retaining the pulley,thick washer and tappered cone this will allow access to the seal and wear ring i personnally found it easier to then remove the seal first and then pull out the wear ring (easy if the ring had 2 puller holes) if no holes were available heat was applied to the ring to expand it off the crank and quickly levered off(don,t warm the crank only the ring) all this work was carried out from underneath the tractor I wish it was as simple on the newer tractors which have the same engine on reassembly take care with the length of pin you put back in the wear ring and if you have the multi tappered cone assy(which holds the pulley on) it,s advisable you clean it with wet/dry for ease of rebuilding and tighten the 3 bolts a 1/4turn each progressivley until tight to prevent pulley wobble
Home
| Forums
| Order Support
Today's Featured Article -
Major Problems - by Anthony West. Following the aquisition of the two Fordsons to my collection I found that I was struggling to move them about. I had considered the possibility of driving the "F" to and from shows but anything other than local rallies was totaly impractical due to its sedate pace. I had also considered buying a landrover and trailer, but the price of a
... [Read Article]
Latest Ad:
1965 International Harvester McCormick Farmall cub tractor 2,500. Two owner tractor. My grandfather bought new in 1966, then we inherited it. Have all the paperwork original manual and all maintenance records. It starts and moves. Comes with underbelly mower, plough, and some other attachments.
[More Ads]
Copyright © 1997-2026 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
