Re: International 574 D239 Help!
Posted by ray on January 08, 2002 at 19:11:01 from (40.0.40.10):
In Reply to: International 574 D239 Help! posted by Bob D on January 08, 2002 at 09:23:22:
Sorry to hear it. I had exactly the same problem and these folks responded with the same advice to me. I tried to warn you when you asked about pistons in a previous post. http://www.ytmag.com//farmall/messages/145790.html
I still haven't checked my compression as the adapter is a little hard to come by, but I believe these guys as it is a little harder to start (spec is 315 - 340 psi). I also read in the service manual that a low sac nozzle is available to reduce startup/idle white exhaust. If I ever run down my problem I'll post the results, but it runs fine and the white exhaust dissappears when the tractor is up to temp and under load.
Good Luck,
Ray
Post A Followup
: Re: Re: International 574 D239 Help!
Today's Featured Article - Major Problems - by Anthony West. Following the aquisition of the two Fordsons to my collection I found that I was struggling to move them about. I had considered the possibility of driving the "F" to and from shows but anything other than local rallies was totaly impractical due to its sedate pace. I had also considered buying a landrover and trailer, but the price of a ... [Read Article]
