Re: Woods Belly Mower-Farmall A
Posted by scotty on November 20, 2001 at 06:53:11 from (199.231.49.128):
In Reply to: Woods Belly Mower-Farmall A posted by Kelly on November 20, 2001 at 06:44:13:
Kelly,
1939 was first year for Farmall A. Tiny is right
on the Woods mower. You cant buy one direct, you
have to go thru a dealer. You dont need hydraulics
you can use a strongarm lift.
scotty
Post A Followup
: Re: Re: Woods Belly Mower-Farmall A
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
