Re: installing lights
Posted by buck on November 11, 2001 at 16:40:13 from (209.240.222.132):
In Reply to: installing lights posted by Jerry on November 11, 2001 at 12:25:23:
May be able to help you a little. first determine if your existing bulbs are 12V and if not get replacement bulbs that fit andalso make sure that the bulb sockets are in good shape or replace them. A simple headlight switch with built in fuse is best because you can control your headlights worklight flashers etc. with the same switch. These switches are easy to mount most anywhere and inexpensive. Your hot power can be most any wire that is hot when everthing else is off but if there is any question just go directly to the battery + or wiring should go from hot to switch to lights. One word of caution should your 12V system have an alternator do not connect/disconnect battery with lights on as the voltage draw and resulting arch and spark can damage some alternators and/or voltage regulators.
Post A Followup
: Re: Re: installing lights
Today's Featured Article - Talk of the Town: What's in Your Tractor's Toolbox? - by Staff. This recent discussion on the Tractor Talk discussion board here at the on-line magazine drew so much response and proved to be so interesting that we wanted to share it with you here. The names of the people participating in the discussion have been left out to "protect the innocent" (to quote a once-popular television series). ... [Read Article]
