Re: Farmall Cub axle:What am I doing wrong?
Posted by Bill VanHooser on October 02, 2001 at 17:33:41 from (12.78.238.23):
In Reply to: Farmall Cub axle:What am I doing wrong? posted by mark on October 02, 2001 at 15:30:57:
Mark, the bolts which hold the axle pivot shaft in place do so by engaging small rounded cutout slots that are cut in the shaft. Once you have the bolts out, you may have to spread the split brackets that clamp onto the pivot shaft. There is nothing else holding the pivot shaft in place. It should come out with some gentle tapping from either end. Good Luck...............Bill
Post A Followup
: Re: Re: Farmall Cub axle:What am I doing wrong?
