Farmall Tractors Discussion Board
Re: F-20 rear rims
Posted by Farmall Gray on February 25, 1999 at 16:53:27:
In Reply to: F-20 rear rims posted by John on February 25, 1999 at 16:21:40:
You might want to look at the rims on a Farmall
C. They would't be correct because they aren't
split rims, but they might work. They mount to
the centers the same way and they are 36". Find a
C and take some measurments. Check the number of
loop clamps and center to center distance on the
bolt holes and make sure the inside diameter is big enough to fit over the F-20 wheel center.
If you want the correct original rims, try posting
an ad on the classified section of this board. I don't know of any other tractor that uses the exact same rims.
Post a Followup
: Re: Re: F-20 rear rims
Today's Featured Article - Talk of the Town: Removin Broken Bolts - by Staff. Another great discussion from the Tool Talk Discussion Forum. The discussion started out with the following post: " How would I remove a bolt thats broken off in a piece of metal and I want to save the treads in the metal and then put in a new bolt. " ... [Read Article]
