Re: Super A pump Pressure Max Throttle, 750psi What to do?
Posted by gene b on July 15, 2001 at 19:14:38 from (63.15.137.152):
In Reply to: Super A pump Pressure Max Throttle, 750psi What to do? posted by Marky on July 14, 2001 at 20:17:20:
possible that the seal on the pump is leaking fluid into the crankcase might need a speedy sleeve on the shaft of the pump and a new seal
Post A Followup
: Re: Re: Super A pump Pressure Max Throttle, 750psi What to do?
Today's Featured Article - Torque Wrenches - by Curtis Von Fange. When working with fasteners a torque wrench can play an important role in the correct assembly of critical equipment components. Lets examine in detail some of the reasons for using a torque wrench along with how to correctly use the variety of wrenches available. Applying the proper torque to a fastener accomplishes a number of tasks. First of all correct torque will hold the parts together. This may seem like a trite statement but � think about it for a second. Engineers have designed ... [Read Article]
Latest Ad: WANTED IH C200 gas engine — complete running motor Wanted complete used IH C200 gas engine in running condition for an International 574 gas tractor. My block has a hole in it and is dead, so a rebuild kit wont do it — need a whole running motor. The C200 also came in the 544 and 674 gas trac [More Ads]
