Re: 300U lift ???
Posted by dick on July 15, 2001 at 08:07:34 from (63.120.111.98):
In Reply to: 300U lift ??? posted by Dale on July 14, 2001 at 22:32:09:
I'd agree with Gus, your inlet screen is probably at least plugged, if not collapsed. It's inside the reservoir, under the seat; getting to it is a fairly major project which is probably why it doesn't get cleaned very often (got to do mine before snow flies again).
If your system is really tight, as you indicate, what's probably happening is that you're sucking enough of a vacuum on the fluid coming into the pump to vaporize it, and that's what's encouraging the foaming. Doing this is realy hard on a pump, and you may be trashing your new one.
Post A Followup
: Re: Re: 300U lift ???
Today's Featured Article - Tractors and the City Boy - by Ken. A few years back I came to the conclusion that city life wasn�t for me. The houses so close together you could hear the neighbors fight, traffic so heavy speed limit signs meant nothing. So I started looking for the ultimate country setting. After many months I found the perfect place, off the beaten path, up a private � mile drive, old stone house which has stood the test of time, out buildings which haven�t stood the test of time, trees, birds, rabbits, and snakes. This is the place! Bought ... [Read Article]
Latest Ad: 65 Massey FERGUSON DIESEL [More Ads]
