Re: 300U lift ???
Posted by Gus on July 15, 2001 at 04:51:52 from (205.188.199.174):
In Reply to: 300U lift ??? posted by Dale on July 14, 2001 at 22:32:09:
Did you clean the screen in the reservoir? Under the seat, I think. Use the trans/hydraulic fluid recommended by IH? Does the pump make an unusual amount of noise under a load? Could it be in the control valve?
Post A Followup
: Re: Re: 300U lift ???
Today's Featured Article - Talk of the Town: What's The "Stuckest" You've Ever Been? - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I was about 14 (part of the problem) when I got stuck. I was disking with a cab equipped IH 966. The window was dirty and I was driving into the evening sun. It was hard to see and it was my first pass down the field. I got the tractor so stuck that the underside of the tractor was resting on the ground. My uncle wanted ... [Read Article]
Latest Ad: 65 Massey FERGUSON DIESEL [More Ads]
