Farmall Tractors Discussion Board
Re: M tranny knock
Posted by john on February 24, 1999 at 13:56:24:
In Reply to: M tranny knock posted by Greg Whittaker on February 22, 1999 at 17:39:59:
I agree with the other two posts. One more thing to try is to remove the lower cover under the hydraulic pump motor. Then look up into the main casting. The upper shaft is the input to the trans and the lower is from the countershaft and exits out to drive the hydraulic pump. If the upper input shaft housing has heavy oil deposits coming out of it then one of the two (or maybe both) bearings is out. This would make the constant mesh gear run with a wobble and the uneven wear pattern could cause tooth breakage.
Post a Followup
: Re: Re: M tranny knock
Today's Featured Article - 50 Tips for Ford N Owners - by Bruce Haynes. Over the years of owning these three tractors, I have managed to refresh what little mechanical knowledge I had and add a little more, thanks to the wisdom and helpfulness of many fellow N owners. So, now it's my turn to share a few of the tips I've picked up. ... [Read Article]
Latest Ad: Massey Ferguson model 65 diesel tractor [More Ads]
