Re: 300 Utility fluid leak and transmission slip
Posted by james harris on April 21, 2001 at 15:10:46 from (216.12.51.220):
In Reply to: 300 Utility fluid leak and transmission slip posted by James Otoupal on August 26, 2000 at 17:43:14:
how much transmission oil go into the transmission and the clutch housing. this tractor is a internation farmall tractor 300
Post A Followup
: Re: Re: 300 Utility fluid leak and transmission slip
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
