Re: F-20 Engine Parts
Posted by graytinker on April 08, 2001 at 02:39:26 from (208.29.96.179):
In Reply to: F-20 Engine Parts posted by Kevin (MPLS) on April 07, 2001 at 18:29:36:
Kevin the F20 motor uses Pured babbit bearing`s for the rods, and the main bearings are roller type. The rod`s have shims to adjust the clearnce but, make sure you mike you`r crank [not the wife] for roundness. The main`s are A lot cheaper if you go to A bearing Supplier And they are still not cheap. Rice Equipment should have all the stuff avieble also Central tractor has A antique parts book with a lot of the parts.
Post A Followup
: Re: Re: F-20 Engine Parts
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha ... [Read Article]
