Re: WD-9 rear-main access
Posted by David Saville on March 20, 2001 at 16:18:21 from (142.165.70.20):
In Reply to: WD-9 rear-main access posted by Greg Robinson on March 20, 2001 at 07:52:32:
The bolts you say are coming up from inside the transmission are locater pins. If you put a nut on those threads you can pull the pin out of the housing. You do not have to take the transmission cover off to get the clutch out. You don't have to take the pulley housing off but it is nice to get it out of the way. Once you get the clutch split apart you have to hold your mouth just right but the pressure plate will come up out of the hole.
Post A Followup
: Re: Re: WD-9 rear-main access
Today's Featured Article - Product Review: Electronic Ignition - by Staff. Oil, for example has come a long way in the last 50 years and I don't use anything but the latest API grade available. I've heard the arguments for non-detergent oils but would never trade it for today's formulations. Paint is another, the modern acrylic enamels are great for resistance to grease and fuel stains, retaining their shine and they last forever; unlike enamels and lacquers . Still another is the alternator. No doubt using the original generator keeps the tractor pure, but for thos ... [Read Article]
