Re: TRANSMISSION BEARINGS
Posted by John on March 16, 2001 at 14:03:13 from (152.34.242.90):
In Reply to: TRANSMISSION BEARINGS posted by bob[pa] on March 15, 2001 at 16:35:00:
It has been my experience with my Cub that these type bearings run from 12 to 20 dollars. They are generally a little cheaper from a bearing supply house like Motion Industries or the like. They will need the number stamped on the bearing. Also, there a generally several different races that match each bearing so you will need the race number, too.
Good luck,
John
Post A Followup
: Re: Re: TRANSMISSION BEARINGS
Today's Featured Article - Talk of the Town: What's The "Stuckest" You've Ever Been? - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I was about 14 (part of the problem) when I got stuck. I was disking with a cab equipped IH 966. The window was dirty and I was driving into the evening sun. It was hard to see and it was my first pass down the field. I got the tractor so stuck that the underside of the tractor was resting on the ground. My uncle wanted ... [Read Article]
Latest Ad: 65 Massey FERGUSON DIESEL [More Ads]
