Re: 300 Utility gets no fire
Posted by dick on February 20, 2001 at 15:09:02 from (199.239.12.58):
In Reply to: 300 Utility gets no fire posted by Odie on February 20, 2001 at 14:38:55:
Sounds as if you've tried everything except what's needed to fix the problem. Couple of things to check, assuming you've got a test meter. Check the voltage between the coil terminal attached to the ballast resistor and the ground terminal of the battery while you are cranking the engine with everything hooked up the way it's supposed to be to run. If you see a steady 12 volts, you have VOLTAGE to the coil, but no CURRENT flow through it. If that's the case, look at the gounding on your distributor (measure the resistance between it and the negative terminal of your battery with the ignition turned off) - shouldn't be over a few ohms, if that. You've basically replaced about all the other wiring, so unless something got hooked up wrong that's a good candidate. If you show a steady 6 volts on the coil while cranking, you may have a bad condenser, or the points are shorted out somehow. Pull the condenser and test the resistance across it with your meter. Should start out "low" and then build up with time until the meter overranges. If that checks out OK, look for a short to ground on the distributor side of the coil (little wire, with the points OPEN). If the voltage at the coil is swinging between about 6 to 9 volts, it's trying to work, and your high voltage which is supposed to go to the plugs is going somewhere else. If none of this gets you where you need to be, let us know. Good luck!
Home
| Forums
| Order Support
Today's Featured Article -
Preventing Tractor Theft - by Staff. The discussion started with the following message: I have a JD A without key start or any locking device. Is there a best way to secure it so the chances of it being stolen are reduced? Following are some of the answers that were received: Take the rotor out of the distributor and hide after each use. The would-be thieves at least couldn't just get on and drive away.
... [Read Article]
Latest Ad:
1965 International Harvester McCormick Farmall cub tractor 2,500. Two owner tractor. My grandfather bought new in 1966, then we inherited it. Have all the paperwork original manual and all maintenance records. It starts and moves. Comes with underbelly mower, plough, and some other attachments.
[More Ads]
Copyright © 1997-2026 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
