Crawlers, Dozers, Loaders & Backhoes Discussion Board
Re: Cessna Hydrauilc pumps
Posted by Hermit on April 21, 2006 at 18:53:19 from (69.21.48.22):
In Reply to: Cessna Hydrauilc pumps posted by td5doug on April 21, 2006 at 09:51:49:
Out of an online catalog. Have fun.
CESSNA HYDRAULIC PUMP
Brand new CESSNA model 24505-LZD. Ideal replacement pump on tractors, backhoes and other mobile equipment. Side ports.
SPECIFICATIONSDisp. 2.98 In³/Rev.
PSI 2,500 Max.
RPM 2,500 Max.
23.2 GPM @ 1,800 RPM
30.6 GPM @ 2,500 RPM Max.
Rotation CCW
Mount 2 bolt SAE B mount
Shaft 7/8" dia 13 tooth splined
IN Port SAE 20
OUT Port SAE 16
Shpg. 12 lb.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
