Crawlers, Dozers, Loaders & Backhoes Discussion Board |
Re: jd350 steering brake grabs
Posted by jdemaris on April 19, 2004 at 14:01:48 from (209.23.28.175):
In Reply to: jd350 steering brake grabs posted by MrBill on April 19, 2004 at 11:22:44:
This is, as asked for, a "quick" rundown on adjustment. This is assuming the adjustments are not rusted fast and the clutches are not swelled or stuck. It's difficult to describe this without photos to follow, but I'll try. Keep in mind, you want to achieve a situation where, when the steering lever is pulled back, first there is some free-play (before contact with the clutch throw-out bearing), then clutch disengagement . . . then just as the clutch is fully disengaged, the brake starts to grab. You DO NOT want the brake taking hold while the clutch is still engaged. That being said, pull the little top cover off the clutch housing you wish to adjust (four bolts). Then, find the initial-adjuster on your brake band - probably takes a 3/4" inch wrench, look for a nut on a threaded stud attached to one end of the brake band. It ought to have flats on it so it wants to rest in one of two possible positions, 180 degrees apart. Turn the nut clockwise until snug (not wrench-tight, just snug). Then back off one turn. Now, notice how the linkage inside the housing operates when you pull back a steering lever. There’s a little threaded rod with a small ball joint at each end. One end is spring loaded and can be popped off for adjustment. When you pull back on a steering lever, that threaded rod actuates a flag-shaft that in turn, pushes on the steering clutch throw-out bearing. The action of the said threaded rod also, at a certain adjustable point, begins to engage the brake. The point of brake engagement is determined by a bolt locked by a jam nut; 3/8" bolt I believe. So, to put things in proper sequence, loosen the brake-actuating bolt and back off for now. Then, set the free play in the steering clutch by popping the threaded rod off and shortening in (by turning in a ball joint end on the threads). If you get an inch of free-play at the start of travel in the steering lever, that's fine. Keep in mind there's probably slop in the lever an linkage too; you must have actual free play in the clutch. You can look down with a flashlight and see the throw-out bearing and clutch fingers if you're not sure. Note: If you cannot get free-play because the clutch pressure plate fingers are too high, the clutches are probably swelled and rusty. It is possible to re-adjust the pressure plate fingers from the outside, but it's difficult. Assuming you've got the free play, and you’ve done the initial adjustment on the brake band, now you want to pull back the lever until the clutch disengages. At that point, adjust the brake actuating bolt so it just makes contact when the clutch is disengaged. This is easier to determine by running the machine. When I worked for John Deere, I'd put the crawler on a steep hill facing up. Put it in forward and start climbing the hill, and then pull the levers back until the crawler rolled backwards. If it won't roll backwards, then the brakes are grabbing too soon. You should have a narrow spot in the lever travel where the clutches are disengaged but the brakes are not quite grabbing yet - that's why the crawler should roll backwards.
Home
| Forums
Today's Featured Article -
Show Coverage: Godfrey, Illinois Country Days - by Cindy Ladage. Except for last fourth of July's Old Gold show in Springfield, Illinois, I don't remember when it was so hot. Nevertheless, the heat didn't keep vendors and visitors alike from enjoying the third annual Country Day's Event. Jane Elliott said the event was originally a one man show. "Barry Seiler, owner of Country Town Farm Supply store used to invite people up to the Johne Deere store. He would give hats and a free meal for everyone that brings a tractor." Elliott said while this
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
