Posted by Tomtom81 on January 12, 2019 at 14:01:40 from (184.156.111.203):
I have a john deere 302-A backhoe. Everything works as it should expect it will not go forward. The reverse works fine. I have replaced the main clutch and replaced the forward clutch pack the old one was burnt up. The hoe is full of oil but still no forward movement I have a manual and parts book for the machine. But it's hard to tell where to check the pressure on the reverser. If anyone can help I would sure appreciate it. I was wondering if you welded up the front clutch pack would it move then and just use it like a regular manual trans just have the reverser for reverse only.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and
... [Read Article]
