Hello I have a ford 7600 that the implements will drift down when the hyd oil gets warm.i think the problem is in the hyd valve under the seat,it is a 2
spool valve with detents. A new valve is not available from ford if I go used I?m afraid I may still have a problem do to the age of the donner tractor.what
I was wondering if the hyd system from a 7610 could be put on the older 7600. Could the 2nd pump be put on the engine remove my 2 spool valve from
under the seat , put on the priority/load sensing valve off the 7610 and hang the valve and breakaway couplers on the back of the tractor
