Organic farming
SVcummins
Going to Burry a little natural Fertilzer. The grass is about 4 to 5 feet tall in places the good grass goes through the plow really well , the morning glory and June grass not so well
Cheap fertilizer ! That rollover must have pretty good clearance ! What's getting planted there ? When we used to plow hay down the corn the first couple years was always really good !
It?s amazing how much more clearance this 642 has verses the 314 rollover the 642 is a 3x16 and the 314 is a 3x14 but the 642 is a lot taller and longer . I think we?re going to plant barley here
SV cummins- I admire that rollover plough you have. It looks like a handy thing for small jobs or unusually shaped pieces of land. unc
It?s great for odd shaped fields they are also nice for
big square fields . I plowed an old piece of ground
last year that had so many rock plies it was terrible
with the two way plow I could work the field the way
to get the longest passes between rock piles.
In this picture there was only about 100 feet
between the rock plies I worked it the long which
was about 600 feet long and made for a lot less
turning around I was able to do that on a lot of
places like that on this field
Might as well plow grass under, it?s worthless now with the new govt PP rules.
The second picture caught me, wrong wheel in the furrow! Ha. Just don?t see those types of plows here, they are interesting, can see their value in odd shaped fields and such, no furrow to bump through in the field for years to come.
Looks like it?s doing a real nice job.
Barley, are you far enough south for winter barley, or are you planning ahead to next spring? Only winter crop that really survives here is cereal rye.
Paul
These plows are nice to use in odd shaped fields I plowed a piece of old ground last year that had a lot of rock piles there was several times I had a section in between rock plies that would only be 100 feet wide but 400 feet long so I could work the little sections like that which ever way would give the longest pass .
I was following the curve of the rock pile on this little section . A two way plow is also nice on a square piece to because you don?t have to cut out lands and finishing the headlands is a lot faster
Is that a white W 900 kw i see?why it in the field?
Always wanted a rollover plow with slatted molboards
