I am thinking of buying a corn binder, and husker shredder to save the corn and make stover out of the shucks. I am thinking of setting 2 24ft utility poles 3 or 4 ft apart. and running boards across from them all the way up nailed other than say 6ft from the bottom which ill set in with boards as I fill it. Then ill run 8ft rabbit wire, 1 X 2in in to joined pieces joined with rabbit clips and build a 20ft circle 16ft high each end steepled to one each of the poles. Then when ive filled it up to within a foot from the top, run another section of the wire for 24ft. Question is, Do you think this will work. Being dry, do you think it will provide too great a strain on the steeples at the poles, and do you think that it will drop out from above as its being taken out from below, or will I have to climb up as in a regular silo?????
