Absent Minded Farmer
- Location
- Gehl Country, Wis.
Hello again,
I'm still pretty new to all the details of growing & harvesting my own pasture mix. I had posted a couple of weeks ago, asking if I should cut my oats green because the pasture mix had caught up to the oats & was a little weedy. So, I was finally able to get it cut down (sickle mower - no crimper) on Sat. I raked on Mon. & baled a little last night. Did I jump the gun somewhere? I ended up with a 50/50 mix of nice dry bales & wet ones. I checked for readyness by picking up a handful & seeing if the stems cracked when bending/twisting. The oats would only crackle & not break. The grasses are deep green & brittle & the weeds were the same as the oats. My questions are: 1.) Without the aide of a moisture tester, what's the best way to tell if my green oats, with a light amount of grasses/weeds, is dry? (I was shown the afforementioned "testing" method a long time ago in red clover & alfalfa). 3.) Do I really need a hay crusher? 3.) Will the sun leach the nutritional value out of oat stem if it dries? 4.) Should I somehow break up the wet bales to dry & then rebale 'em? 5.) Should the wet one maybe get fed out right away? 6.) Who should I sell to. (What animal is going to eat all of this nonsense?!) Thanks in advance & thank you to those of you who replied to my previous post. - Mike
