I inherited an old blue Homelite Super Xl Automatic Oiler chainsaw. It had bad rod bearings so I replaced the rod bearings, honed the cylinder, put in new rings.
After the rebuild it will start and idle but not rev up. It will bog down when wide open throttle is applied but will not rev up or even pull the chain across the bar. I took the chain off but still no luck. As it runs it spits a lot of gas out the muffler. So much gas comes out the muffler it will wet the ground it is sitting on. The gas is new and the oil is the correct mix.
It has had the points taken out and an electronic ignition module installed, before I got it. I installed a new plug, and it seems to be getting enough fire as it arcs a blue spark at a .025 gap. I have put a ¼ inch gap in an old spark plug and it will jump an orange spark across that.
It has plenty of compression and the muffler is open and has no restrictions. The fuel line is new and the filter in the tank is good as I have cleaned it to make sure is not restrictive.
I have rebuilt the SDC Walbro carburetor. It has new everything even changed the welsh plugs and I am 100% certain it has no restrictions. I have adjusted the metering lever that connects to the needle valve and diaphragm in several combinations which include the factory setting, as well as rich and lean conditions. Could I have a bad carb?
So far in about 100 times of me starting the chainsaw it has reved up to wide open throttle for 15-20 seconds or so a grand total of 5 times and only when I feather the throttle.
Does anyone have any suggestions besides using it for a parts?
