Ok Today I replaced the master cylinder.
bench bled it, and plugged the ports as described. removed the old cylinder and hooked up the lines.
Had an assistant hold the metering valve as I pumped the peddle and another assistant opened the bleeders on each wheel as described in the Chilton's manual Furthermost from the master cylinder first and work back to shortest .
Seems to get full peddle with engine off after pumping twice-- hold peddle and start engine the peddle will go down to about 2" from floor.
Bled them again took it for road test, no such thing as a panic stop and still a mushy peddle.
What am I doing wrong ??
