Lloyd In South Carolina
You all have seen my gate project, dug the holes to set the posts this past weekend, neighbor used his Bobcat posthole auger, made quick work of that.
However, 30 mins after he left the holes (one is 6' deep, the other is 6'6" had filled in with 12 to 18" of water!! The plan was to mix concrete and set them in it,,, however not if the holes are wells!!!
Suggestions?
These are 8"x8" I beams, hinge brackets are welded to them, holes are diff lenghts cause the beams were scraps that are odd lenghts. Gates are heavy, want to make sure they do not sag overtime.
Thanks for any ideas!
Lloyd
Suggestions?
Lloyd
