Remote Hydraulic Coupler Help
WI Dave
My Farmall H and Allis WD both have a single rear hydraulic remote. They"re both Pioneer #4050-4. Can I still get the male end for these? I had no luck at TSC. Is the male end still available, or should I just replace the female ends?
I learned a long time ago just to switch all my stuff the the newer common universal type so I do not have to fight with stuff just to use it on a tractor so all mine have one type and all the others end up in a box in my shop
Rich is right. Even newer tractors from the 1970's have available changeover kits to switch them to a universal Pioneer size. Deere, IH and Case have them. Don't know about the other brands.Jim
Hope I'm not too late.
I just looked at my WD45. The coupler body is the same number as yours. It's a ball type. Works fine with all the standard Pioneer ends I have.
(quoted from post at 14:58:03 03/27/11) My Farmall H and Allis WD both have a single rear hydraulic remote. They"re both Pioneer #4050-4. Can I still get the male end for these? I had no luck at TSC. Is the male end still available, or should I just replace the female ends?
The #4050-4 is the female part and it is available so I imagine the male tip is also available. No need to do any changeovers. Just send me an email. It's open in the modern version.
The VP8010-4 is one of the four male ends I tried. The female end wouln't "latch" onto any of them. Maybe the fitting already on the tractor is no good. I haven't returned it yet, so I'll go try it on the WD remote.
The problems were with the female end on the tractor. The male end from TSC does indeed work fine.
